Re: Re: Re: H battery won't charge
Posted by Bob M on June 18, 2001 at 18:28:05 from (66.66.72.246):
In Reply to: Re: Re: H battery won't charge posted by jimbub on June 18, 2001 at 16:03:40:
jimbub - That lone terminal on the backside of the regulator is the "A" terminal. (Sometimes it's marked "GEN" or "ARM" instead of "A").
To polarize the generator, use a jumper wire to momentarily connect the B and the A terminals at the regulator. Do this with the motor shut stopped...
BTW 4 amp output for a Farmall generator is way low. A good one will show 12 to 15 amps on a bench test.
Post A Followup
: Re: Re: Re: Re: H battery won't charge
