Re: Distributor update
Posted by Steve Wisnewski on June 19, 2001 at 09:14:42 from (199.46.199.232):
In Reply to: Distributor update posted by FC on June 19, 2001 at 05:14:45:
At one time a company was making repair bushings from a plastic material to be used to repair GM distributers. I have actually used these kits several time with really good luck. The idea was to drill (came with kit) the weight hole to match the bushing and then install the assemble over the weight post. Since the bushing was a little longer than the post, it took the play out of it also. The kit came with an assortment of weight springs also. I have no idea if it is still possible to buy these kits anywhere. Does anyone know if they still available?
Post A Followup
: Re: Re: Distributor update
