Re: Thermo-Siphon Question
Posted by FC on June 19, 2001 at 09:17:01 from (208.14.16.15):
In Reply to: Thermo-Siphon Question posted by Kenneth Fass on June 18, 2001 at 14:40:36:
I agree with the others... if this started fairly suddenly, you probably have a restriction....collapsed hose, crud in passage, etc. I recently had to remove the lower hose fitting which bolts to the block to repair a broken drain and found a lot of scale, etc in there. Removing radiator and flushing all out well with a hose might prove effective. Another thought...is fan belt loose or slipping?
Post A Followup
: Re: Re: Thermo-Siphon Question
