Re: B fluid level
Posted by Vern on June 19, 2001 at 22:21:37 from (64.20.241.182):
In Reply to: B fluid level posted by greg central wis on June 19, 2001 at 19:30:12:
According to my Super A book, the transmission drain is below and forward of the belt pulley near where the PTO shield bolts to the housing.
The Super A takes 4qts. if no pulley and 5qts with. 90 wt. gear lube will work fine although Hy-tran is what some recommend. It is available at dealers.
I think the B and the Super A are the same in this respect.
Post A Followup
: Re: Re: B fluid level
