Re: Click Means Bad Solenoid or Starter?
Posted by ferrell on June 20, 2001 at 04:28:31 from (204.157.225.129):
In Reply to: Click Means Bad Solenoid or Starter? posted by Bob Kirk on June 19, 2001 at 18:30:44:
Have checked the battery cables and terminals. On some IHC grounding can be problem ,you might have to change our ground . One easy way to check this is with good set of jumper cables ,hook the ground up then poistive up with cables. Check the ground stud or bolt making sure you have good surface for ground .Paint and rust or even the bolt can cause a problem. Battery cables can cause you the same problem ,thats why I, use the jumper cables .
Post A Followup
: Re: Re: Click Means Bad Solenoid or Starter?
