Re: B fluid level
Posted by Red Dave on June 20, 2001 at 05:03:19 from (208.165.46.34):
In Reply to: B fluid level posted by greg central wis on June 19, 2001 at 19:30:12:
Yes, the transmission and rear end drain together. I don't remember for sure, but there may be another drain on the PTO housing itself too. It sounds like it had moisture in the lube making it milky. The check plug is on the left side of the trans under the rod that operates the left brake. Fill with 90w or 90-140 until some comes out that hole. Don't overfill it or it'll run out the differential shaft seals.
Post A Followup
: Re: Re: B fluid level
