Re: H belly pump troubles
Posted by Doc on June 21, 2001 at 17:16:39 from (204.73.55.10):
In Reply to: H belly pump troubles posted by jmyt_47 on June 21, 2001 at 07:37:09:
I would hook a pressure gauge inline before pulling it apart. Should be about 800 psi. The other thing is to set the contol rod for the belly pump in the neutral position, pull it to the lift position and see if the engine slows. This would indicate the belly pump is working. Doc
Post A Followup
: Re: Re: H belly pump troubles
