Re: Re: Differential experts needed!
Posted by John on June 22, 2001 at 15:23:26 from (165.247.157.151):
In Reply to: Re: Differential experts needed! posted by Al P. on June 22, 2001 at 14:59:33:
Thanks, Al. I should have stated that I have done this to get the desired contact pattern as illustrated in the manual. The pattern looks good, but still makes a lot of noise. I hope you have much better luck.
John
Post A Followup
: Re: Re: Re: Differential experts needed!
