Re: W-9 stuck clutch
Posted by Redfan on June 26, 2001 at 05:14:34 from (203.87.49.4):
In Reply to: W-9 stuck clutch posted by Verlyn Moen on June 25, 2001 at 18:24:47:
You may not have to remove the clutch totally. Just remove the clutch cover and that will enable you to access the clutch components. If needed, you can dissassemble the connecting link between the clutch and G'box, and then work on releasing the pressure plate and clutch plate. W9 clutches can be removed without a split, but be very patient.Regards, Redfan.
Post A Followup
: Re: Re: W-9 stuck clutch
