Re: How tight is sludge???
Posted by Duner Wi on June 28, 2001 at 10:36:37 from (63.50.13.15):
In Reply to: How tight is sludge??? posted by KB6 on June 28, 2001 at 10:28:09:
I would install a known good battery and if that did not help I would then check the wiring for good connections.
I don't think it is the sludge causing problem.
You might want to change engine oil after a few hours also.
Post A Followup
: Re: Re: How tight is sludge???
