How tight is sludge???
Posted by KB6 on June 28, 2001 at 10:28:09 from (151.201.73.2):
I purchased a Super C that has not run in 6 years. I have done the following:
-- All new wires (plug, battery, generator & starter).
-- I had the starter and generator overhauled and cleaned.
-- Changed all fluids.
-- Dropped oil pan and cleaned out sludge. Former owner only used non-detergent oil and it shows.
-- Removed value cover and cleaned out more sludge.
Here what happens. When I go to start it I can hear the starter engage the flywheel. The motor grunts and turns slightly. I thought maybe starter was bad. I took starter from my other Super C which works great and put it in this one. Same result, no start. I can turn the motor with the crank so I know that the motor is not stuck "on center". My question is could sludge in the block be responsible for not allowing the motor to turn over when I pull on the starter? I'm about ready call the neighbor over and have him pull me around the yard and make the tractor start. Any ideas? Thanks.
Post A Followup
: Re: How tight is sludge???
