Re: 656 carburetor
Posted by bc on March 15, 2009 at 08:32:49 from (68.88.175.43):
In Reply to: Re: 656 carburetor posted by Owen Aaland on March 14, 2009 at 00:00:24:
Mine still had the needle on it. They put an oring on the threaded part and screwed the whole thing in. Basically used the whole solonoid to adjust the needle by screwing it in or out till it was running right. Sometimes hard to keep it from leaking past the oring and threads though which is part of the reason why I replaced it with a needle.
