Re: Changing Rear Tires
Posted by RAW in IA on July 02, 2001 at 04:48:42 from (206.28.170.207):
In Reply to: Changing Rear Tires posted by F-Dean on July 02, 2001 at 04:17:15:
I changed on on our F-20 last summer, but it did not have fluid in int. The old one roted till it blew, that's how long it was on. Had to cut the bead to get it loose. After that it was not bad, the "new" used opne went on gairly easy. With fluid I would think you would be just as well off taking it to a tire place. In fact I did that with my cub which had fluid in and had to replace one rear tube. Had the fluid left ou opn that tire. Good luck. Roger
Post A Followup
: Re: Re: Changing Rear Tires
