Re: Points and starter
Posted by dick on July 02, 2001 at 19:10:10 from (63.120.111.98):
In Reply to: Points and starter posted by Rob in Wis. on July 02, 2001 at 18:58:47:
Points: mark the position of your current distributor (timing) setting on the distributor bracket. Rotate the distributor until the points open up and set their gap. Rotate the distributor back to your mark (you'll have to reset the timing anyway since you changed the points, but the mark should get you close enough to get the engine started OK).
Starter: before doing anything very involved with the starter, look over ALL the electrical connections for corrosion, tightness, etc. About 90% of the time that's where the problem is for the symptom you're describing.
Good luck, and have fun.
Post A Followup
: Re: Re: Points and starter
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
