Re: Re: Re: setting the timing
Posted by gene b on July 05, 2001 at 19:50:50 from (63.15.137.239):
In Reply to: Re: Re: setting the timing posted by Edd on July 05, 2001 at 19:27:43:
check if #1 is on compression and if the plug wires are ok there is no setting the timing on a mag it will start on impluse and then when it runs there is like 34 degres advance but to start it is on dead center you CANNOT advance the timing on the stock mag that is original equipment read the manual it is explained in detail
Post A Followup
: Re: Re: Re: Re: setting the timing
