Re: Re: Oil pressure M diesel
Posted by paul on July 07, 2001 at 17:46:33 from (172.142.228.88):
In Reply to: Re: Oil pressure M diesel posted by Medfarm on July 07, 2001 at 10:53:48:
Ray you gave me some wonderful info did in fact check the items that you mentioned. pulled diesel lines and filter apart water catch and filters looked great. While cranking oil press came up past 1/2 so feel confident about inserts and oil system other than clean out as necessary. Problem that I ran into was carb f-8 the bowl was cracked and leaking plus the float didn't work no float will be necessary to obtain a carb pretty simple thing thios carb cain;t fix with the problems that I mentioned So in market for f=8 carb. thinks for all info.
Post A Followup
: Re: Re: Re: Oil pressure M diesel
