Re: Re: 41A Cutout question
Posted by Dave on July 09, 2001 at 10:19:26 from (138.29.169.43):
In Reply to: Re: 41A Cutout question posted by Ralph on July 09, 2001 at 10:03:53:
The 20 volts does drop under load: when I put the 12 volt battery in series it drops to about 13 volts with 7 amps of charge.
I'd like to go a 12 volt system, but I need the cutout to do it right. If I can't find the cutout, I'll buy the cheap battery and go back to 6 volts (I went to 12 because I had a good used 12volt batt laying around, plus they are cheap, and start good). Right now I have the 6 volt cutout rigged up with the points far apart and a 25 ohm resistor in series with the fine wire coil to make it close at 12 volts instead of six. It closes slowly, though. I wonder if anyone has had any luck with a big 10-amp diode?
Tks,
Dave
Post A Followup
: Re: Re: Re: 41A Cutout question
