Re: MD Injector Pump Timing
Posted by Ralph on July 11, 2001 at 05:50:36 from (64.20.91.178):
In Reply to: MD Injector Pump Timing posted by Roger on July 10, 2001 at 20:18:03:
Roger: I would have thought IHC would have a prescribed method of setting the timing rather than hit or miss. For trial and error method you might consider hooking up to a dino and adjust for max power at full rated PTO speed. I did the trial-error method with a perkins diesel running at full PTO RPM under heavy load as a referance. Got less black smoke and more power. Too far advance seemed to hear combustion rattle more at idle. R.
Post A Followup
: Re: Re: MD Injector Pump Timing
