Re: Re: Re: Cub will not start now.
Posted by Bama Binder on July 16, 2001 at 10:06:42 from (206.5.110.200):
In Reply to: Re: Re: Cub will not start now. posted by Ryne on July 16, 2001 at 09:24:49:
I would go with the factory spec .020 on the points. the .013 is correct for magneto equipped tractors. The 52 should have battery ignition therefor .020 Yes...if you put the distributor on in a different location, you could and probably are way off on your static timing. I would fix the wires and try it...if it starts, you can probably adjust it from there. There are probably several ways to skin this cat, but I would start by pulling plug on #1 and put your finger over the hole and turn the engine over by hand until you have compression blowing past your finger. Then find the timing mark on the front flywheel. Line up the metal pointer on the side with the timeing mark. This should be TDC on #1. Pull off the distributor cap and check the location of the rotor. If it isn't close to 10 o'clock, you will have to remove the distributor and turn the rotor to the 10'oclock position and re-install. Then, Loosen the distributor so you can rotate it. Take the #1 plug and connect it to the wire and ground it against the block. With the ignition on, rotate the distributor until the plug fires. In theory, the plug will be firing with the #1 piston at the TDC location. Tighten up the distributor and go for a ride. If you can't find the timing mark on the front crankshaft pully, there is another way to do it, but it involves taking off the hood. Let me know and I'll try to help you through that...BB.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
