Re: Re: Cub will not start now.
Posted by Ryne on July 16, 2001 at 09:24:49 from (216.174.25.85):
In Reply to: Re: Cub will not start now. posted by Bama Binder on July 16, 2001 at 06:51:09:
Thank for the GREAT answer.
I think I have the distributor wires in the wrong holes.
I set the points at .013 as it said in the book. I replaced all the parts in the distributor so do I still set the points at .017?
Now I have another question.
I could not get the point adjustment screw out it was worn and would not turn, therefor, I removed the distributor completely By removed the two bolts and brackets on either sided of the gear box. Then I removed the adjustment screw and changed all the points.
I replaced the distributor just as I removed it, however I am sure I did not put it in the gear teeth in the exact spot in which I removed it. Did I mess up? If so how do I fix this if it?
Post A Followup
: Re: Re: Re: Cub will not start now.
