Re: Need Help! H dieing at high RPM under load
Posted by Charlie on July 16, 2001 at 18:04:03 from (209.130.132.238):
In Reply to: Need Help! H dieing at high RPM under load posted by Weekend Farmer on July 16, 2001 at 04:54:11:
Like the guys are saying it sure sounds like a fuel problem but you are describing the same symtoms my M has when it needs new points and condenser. You could remove the drain plug from the carburator and see if you get a good stream of gas for several seconds. If not its a fuel problem. If you do get a good flow I'd try the points and condenser.
Post A Followup
: Re: Re: Need Help! H dieing at high RPM under load
