Re: Cause of little or no oil pressure in MD
Posted by Haas on July 18, 2001 at 05:51:50 from (129.37.117.205):
In Reply to: Cause of little or no oil pressure in MD posted by Ross on July 17, 2001 at 19:23:24:
There is a very good possiblity that the diesel injector pump has a bad seal and is leaking diesel fuel into the crank case. First thing is change the oil in the crank case. Be sure to change the filter too. Before you change the oil, check the level if it is high, you may be leaking the diesel fuel. The proper level on the crank case oil is checked with the dip stick. Unscrew the dipstick and wipe it off. then reinsert but do not screw it in then withdraw and check level. In your case, I would use a 30 wt oil rated ro diesel service. The manual calls for 20 wt in the MD up to 90 degrees, but since you have low oil pressure, try the 30 wt. I am using Shell Rotella T 15W-40 in my MD. Also, take the oil gage off and check to be sure the line to it is not stopped up and that it is working properly. If it's none of these things, then it's the oil pump or some other internal engine problem such as worn bearings. I drove an MD many hours when I was a boy. The oil pressure gage on it always ran against the high peg when at full throttle. I have one now that I restored and it is the same. The gage only drops to mid range when the engine is at idle. According to the MD service manual I have, the engine oil pressure is supposed to be 60 to 70 psi. Also, the manual says there is a spring loaded oil pressure regulator valve located in the base of the oil filter housing. It's contained behind a retainer nut in the front side of the base. Good Luck. I really suspect your problem is thin oil due to diesel fuel leaking into the crank case and if not that, a bad pressure gage especially if the thing seems to be running normally.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
