Re: More With H Steering
Posted by Bob M on July 18, 2001 at 10:32:35 from (192.232.119.194):
In Reply to: More With H Steering posted by 1PWRFULH on July 18, 2001 at 09:47:44:
Sounds like the bolser pivot shaft thrust bearing has failed. When the front end is jacked up can you see signs of wear on the underside of the upper bolster casting where the top of the pivot shaft flange (where the lower bolster bolts on) has been rubbing? If so that's a sure sign the thrust bearing is gone. If no wear is noted, then perhaps the nut that holds the sector gear onto the top of the pivot shaft is loose or missing - which can make your steering REALLY sloppy! First thing to to would be to remove the grille and the steering gearbox cover for a peek inside, then jack the front end. That should show you the source of the vertical play. Good luck!!
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
