Re: question for Bob M. and others
Posted by Bob M on July 23, 2001 at 13:51:11 from (66.66.72.246):
In Reply to: question for Bob M. and others posted by joe on July 23, 2001 at 13:11:09:
Joe - If you are already running 12 volts and your coil and points have not burned out yet, you've probably got a "12 volt" coil and thus don't need a ballast resistor.
You must go negative ground with an alternator - that's inherent in the standard GM alternator design.
The warning light is required because the alternator won't work with out one. If you leave it out the alternator won't charge. If you bypass the lamp (wire direct from the ign switch to the alternator #1 terminal) the tractor won't shut off when you turn off the ign switch. You can substitute a resistor (12 ohms, 5 watt or higher) for the lamp, but I find it's easier simply to use the warning light.
As for wiring the ammeter, simply try it. If it reads backward then swap the wires on both terminals.
Post A Followup
: Re: Re: question for Bob M. and others
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
