Re: Re: Re: Re: Farmall 400 Inter Axle Bearing
Posted by wayne on July 25, 2001 at 10:00:10 from (209.23.129.37):
In Reply to: Re: Re: Re: Farmall 400 Inter Axle Bearing posted by Jon on July 25, 2001 at 06:43:57:
You guys are all wrong.. To remove the inner axle bearing, you have to have the tractor supported on the axle housing. Remove the trans deck, and remove the retainer bolt that holds the axle to the bull gear, and remove the outer axle bearing/seal retainer cap. With the cap removed and the bull gear retainer removed, you can pull the axle out thru the axle housing (you will probably want someone to hold on to the bull gear as the axle is pulled away). With the axle removed you can remove the bull gear, and then unbolt the inner bearing retainers. Next all you need to d is replace the bearing, and reassemble in reverse.. alot easier than takind the whole housing off as one unit.. If the gasket between the axle housing and the trans case is leaking, I would remove the housing and replace the gasket..
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
