Disc Brakes on Super M
Posted by Bart on July 27, 2001 at 11:21:56 from (170.222.245.198):
Just replaced discs on SM. I thought I had them adjusted to the book but they are locking up tight. First one wheel and then the other every time I push the brake pedal. I used a small dab of white grease on the 7/8 ball bearings the help them slide. Wrong stuff? Wrong adjustment. Seems like the balls are not sliding back into position after bake pedal release. Also all new springs from int/case dealer. I am going to disassemble them again and emery cloth the ball channels clean. Anybody been there, done that? Thanks for any help
Post A Followup
: Re: Disc Brakes on Super M
