Re: Disc Brakes on Super M
Posted by Denny Frisk on July 27, 2001 at 11:37:47 from (12.4.181.2):
In Reply to: Disc Brakes on Super M posted by Bart on July 27, 2001 at 11:21:56:
Those disc brakes are VERY sensitive, That's kinda the way the work, Self-Energizing! Sounds like Your problem is They won't release. The 3 big ball bearings are the key! Also the pivot points where the actuating links connect should get a little dab of grease too. Clean the grooves where the balls roll up good as You said, then a thin coat of grease and You should have them working as good as they're going to. These brakes are not a progressive brake like a rotor and caliper type brake. They have to "SNAP" into engagement before You can back off on them, and You can fell them engage and disengage thru the whole tractor.
Post A Followup
: Re: Re: Disc Brakes on Super M
