Re: Farmall A, correct Mag?
Posted by Kurow NZ on July 31, 2001 at 22:13:23 from (203.96.111.202):
In Reply to: Farmall A, correct Mag? posted by Gregg on July 30, 2001 at 20:04:07:
I have a 44A. The"correct'mag is the IH H-4 mag. In the early models the cut off switch was on the side of the mag which was a bit fussy and it was then changed to the cutoff switch attached to the steering coloumn arm. But still same basic mag.
rgds
Post A Followup
: Re: Re: Farmall A, correct Mag?
