Farmall Tractors Discussion Board
Re: Farmall Cub electrical problem
Posted by bronco on February 26, 1999 at 20:07:15:
In Reply to: Farmall Cub electrical problem posted by Norville Web on February 26, 1999 at 18:59:10:
I also have a 6v Cub, it doesn't take much to use up battery on those. I would check the switches, both ignition and light for a short, that may give you the shock and run the battery down.
Post a Followup
: Re: Re: Farmall Cub electrical problem
