Re: mounting mag on H
Posted by justin on August 08, 2001 at 07:58:03 from (209.23.129.53):
In Reply to: mounting mag on H posted by mikew on August 08, 2001 at 07:45:59:
With the tractor set a TDC on the Number 1 cyl, and the mag set at the number one, loosely bolt the mag to thetractor, so you can turn it. Push the top of the mag as far towards the tractor as possible. Next crank the tractor one complete revolution to the same pointer mark, then pull the top of the mag away from the block until it trips. the mag must be held at this point and bolted down.. now the tractor is in time..
Post A Followup
: Re: Re: mounting mag on H
