engine
Posted by vince on August 09, 2001 at 05:57:41 from (65.162.105.162):
My 41' H has just had the carb rebuilt, the packing at the bottom of the power needle located on the bottom of the float bowl had disetegrated so I replaced it. Pretty straight forward. Well now I can't get the engine to run for more than a few minutes without having to clean the plugs. When I remove them they're wet and sooty. I've adjusted the air fuel mix and the power needle while it ran and seemed to run fine for a short time then it dies. The carb is an IH model. Any pointers appreciated, I hope this is enough to go by. I've used my I&T manual during this proceedure. Regards to all.
Post A Followup
: Re: engine
