Re: Re: Re: Charge it, please...
Posted by Bob M on August 13, 2001 at 14:04:14 from (165.170.128.65):
In Reply to: Re: Re: Charge it, please... posted by HavinFuninMo on August 13, 2001 at 13:25:58:
You got it! Only the regulator cares whether you're positive or negative ground. You don't do a thing to the battery - just reconnect so the ground cable is on the battery positive (+) post.
Incidentally the ammeter doesn't care about grounding either - it simply reads backward (deflects to the left for charge and right for discharge) if hooked up with the ground reversed.
Now "have fun"!!
Post A Followup
: Re: Re: Re: Re: Charge it, please...
