Re: Re: Charge it, please...
Posted by HavinFuninMo on August 13, 2001 at 13:25:58 from (64.196.152.8):
In Reply to: Re: Charge it, please... posted by Bob M on August 13, 2001 at 12:51:05:
Thanks Bob. Couple follow up questions to ensure I got this right. The regulator is the only piece of hardware that really "cares" if it is positive or negative ground? Do I need to drain the battery and recharge or does it not change anything with the battery other than which lead goes where?
Thanks again
Post A Followup
: Re: Re: Re: Charge it, please...
