Re: Re: 1941 M going dead
Posted by Gary L. Davison on August 15, 2001 at 20:54:44 from (206.72.58.16):
In Reply to: Re: 1941 M going dead posted by cornfused on August 15, 2001 at 15:58:20:
Sounds like a similar problem I had with my 47 M. I had rust and sediment in the tank which kept coming loose and plugging the inlet in the tank. What I did was take out the sediment bulb assembly and went to a JD dealer and got a screen assembly and fixed it on the end which goes up into the tank. You have to bore out the inlet to 3/8 inch and JB weld the screen assembly in the inlet. the screen is about 2 inches long and is JD part # n AR10104. Mine runs great now! Good luck!!
Post A Followup
: Re: Re: Re: 1941 M going dead
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
