Re: Re: Re: 1941 M going dead
Posted by S-E Michigan Part Timer on August 16, 2001 at 15:47:16 from (198.208.223.35):
In Reply to: Re: Re: 1941 M going dead posted by Gary L. Davison on August 15, 2001 at 20:54:44:
Do you get good flow from the line if you open the bowl valve with the line disconnected from the carb? If you haven't tried, pull the line at the carb, and let it run for a few minutes. Just long enough that you know that it isn't just running out of the line, but actually from the tank. That'll help you narrow from carb to tank/filtration...
Good luck!
p.s.- Though this won't be any help, Dad had one on his '51 M that just wouldn't stay running such as yours. He tried everything as suggested above, and finally borrowed the carb of my '50 M and it ran fine. His had been rebuilt twice, last by a pro which 'dipped' it. He picked up a used carb, and it still runs fine. Sometimes they just have Gremlins..
Post A Followup
: Re: Re: Re: Re: 1941 M going dead
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
