Re: H and M throttle shaft interchangeable??
Posted by Bill Smith on August 16, 2001 at 18:40:31 from (128.242.4.59):
In Reply to: H and M throttle shaft interchangeable?? posted by ff316 on August 16, 2001 at 16:17:05:
I am not sure if the length is the same. If it is it will probably work. If your old one is just bent you could just bend it back straight. I am pretty sure they were straight as an arrow when new.
Post A Followup
: Re: Re: H and M throttle shaft interchangeable??
