Farmall Super A tie rod adjustment...
Posted by James on August 19, 2001 at 10:23:38 from (24.159.57.171):
I just recently bought a '53 Farmall Super A. I am in the process of expanding the front end to make it a little wider. My problem is in the tie-rod. One end is adjustable (threaded tie rod end) and the other does not move at all. I am unable to determine if the outer end of the tie rod (connects to the idler arm) is pressed in or threaded. If possible, I can call you if you send me your ph. number. Otherwise, email should work fine. Thanks for the help.....
James Lemons
blackhawkip@charter.net
Post A Followup
: Re: Farmall Super A tie rod adjustment...
