Re: Super A Front End - Need Some Opinions
Posted by bob on August 20, 2001 at 16:26:59 from (24.24.74.80):
In Reply to: Super A Front End - Need Some Opinions posted by JC in TX on August 20, 2001 at 12:25:14:
if it steers down the road straight than why change it? the weld is stronger than the pin farmall put in. spend your money on paint and a case of beer instead.
Post A Followup
: Re: Re: Super A Front End - Need Some Opinions
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
