Re: Super M hydrolic question
Posted by Bob M on August 21, 2001 at 04:53:32 from (165.170.128.65):
In Reply to: Super M hydrolic question posted by Jack on August 20, 2001 at 18:56:07:
Jack - You don't want to cap off the pump so it's running without oil. There's bearings and a gearset in there that'll fail in short order.
No problem however plumbing a runaround loop to the pump using the old reservoir tank as you suggest.
Another alternative: Remove the hydraulic pump and replace it with a distributor extension housing/shaft from a non-live hydraulic equipped M or SM. That'll permit you to remove the hydraulic pump and reservoir completely - probably 150+ lbs savings. And if the live pump is still good it should be no problem selling it for a couple hundred $ - seems people are always looking for good live pumps.
Post A Followup
: Re: Re: Super M hydrolic question
