Farmall Tractors Discussion Board
300 Utility -repairs
Posted by Tom on February 28, 1999 at 15:15:45:
I've had my tractor about a week now. Overall, its a pretty good old tractor, but has a couple of things I would like to fix. One is the 3-pt. hitch driffs down. It has a leak on the control
valve. Can this be rebuilt? Where can I get the parts? Also, the tractor will only run good when the choke is in the closed position. I guess the carb. needs rebuilt. Same question as above, mainly where to get the carb kit. Thanks a lot.
Post a Followup
: Re: 300 Utility -repairs
