Farmall Tractors Discussion Board
Re: 300 Utility -repairs
Posted by Allan Noyes on February 28, 1999 at 18:55:04:
In Reply to: 300 Utility -repairs posted by Tom on February 28, 1999 at 15:15:45:
Any Case I.H.C. dealer should be able to get a carb kit for you, if you don't have a local dealer try Central Tractor Parts. There number toll free is 1-888-828-3276 or fax 1-800-433-1209.I have ordererd from them and have had very good luck. Be sure to check the 3 bolts that hold the front axle stay rods in place, they are located under the belly of the tractor. If they fall out the stay rod socket clamp will be lost and it could wear a hole in the oil pan loosing all the engine oil and could ruin the engine. This is a common problem on I.H.C. utilitiy tractors. Good luck.
Post a Followup
: Re: Re: 300 Utility -repairs
