Farmall 560 gas hydraulics
Posted by Harold Walls on August 21, 2001 at 14:34:28 from (208.62.247.145):
I have a 1961 Farmall 560 gas with triple valve hydralics & 2 pt hitch. The 2 point hitch(drawbar) has a delay(maybe 3 or 4 minutes) in settling after moving up or down when you reposition the control lever(it may crept up or down 3 or 4 inches. After I let the tractor set for 15 months & draining about 1/2 cup of water
from the drain plugs underneath, now as soon as I start the tractor, the drawbar raises to the top & will not drop. Must loosen hose & bleed off fluid, but it repeats again on restarting. Could something in the control valve assembly be leaking/stuck?
Post A Followup
: Re: Farmall 560 gas hydraulics
