Re: M head
Posted by charlieu on August 23, 2001 at 20:47:30 from (216.188.194.85):
In Reply to: M head posted by Randall on August 22, 2001 at 18:27:33:
Cracked heads on the old "M" are common. Some cracks on these old tractors are no proplem, Most M heads will show cracks coming from the coolant passages and they will not hurt anything. The cracks that need serious welding are the bigger ones in the combustion chambers. I have a SMTA that has some hairline cracks in the combustion chambers. I found these last summer when I installed a new set of rings, and did a valve job. I decided to give the old cracked head a try, and if there were any problems it would not be that hard to slip the head off and send it to Williams Cylinder Head in Iowa for welding. Guess what? She runs just fine, no leaks and last fall, I used this tractor for plowing so she gets a good work-out.
Post A Followup
: Re: Re: M head
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
