Re: Will 6 volt generator work on 12 volt, part 2
Posted by gene b on August 27, 2001 at 20:02:07 from (63.25.166.139):
In Reply to: Will 6 volt generator work on 12 volt, part 2 posted by dick on August 27, 2001 at 19:43:59:
you are trying to get crazy readind the windings in the armature and the fields determines the voltage where were you in science class look in the parts for fields they will be different for 6to 12 same for the armature go look it up if you dont believe me the 6v gen put out around 7.2 or so just look in the service literature for the DELCO-REMY GENERATURES if you can put out 12v@10 amps or so on a 6v generator better get a job with DELCO-REMY and make a mint
Post A Followup
: Re: Re: Will 6 volt generator work on 12 volt, part 2
