Re: Re: Re: Re: Re: RE: Farmall H clutch pilot bearing lubrication
Posted by The Red on August 31, 2001 at 05:43:35 from (12.84.239.204):
In Reply to: Re: Re: Re: Re: RE: Farmall H clutch pilot bearing lubrication posted by Slappy on August 31, 2001 at 05:40:14:
Slappy I wouldn't lose much sleep on that one. I don't recall if I have ever greased that particular fitting on my Hs.
Post A Followup
: Re: Re: Re: Re: Re: Re: RE: Farmall H clutch pilot bearing lubrication
