Farmall Tractors Discussion Board
Re: What to use for wires
Posted by john on March 01, 1999 at 13:56:23:
In Reply to: What to use for wires posted by Ludwig on March 01, 1999 at 09:05:35:
When you change the fluids don't forget the "gear" lube. It's most likely been in there since '52. To do this pull the lower rear plug under the pto unit. Then pull the lower plug under the hydraulic motor cover. In all about 7 gallons of oil will drain. To replenish add either 90W or 140W up to the level of the side plug found near the clutch pedal shaft. When the plugs are pulled let this oil drain for several days.
Post a Followup
: Re: Re: What to use for wires
