Re: New magneto
Posted by Jim Becker on September 12, 2001 at 07:00:40 from (4.61.16.38):
In Reply to: New magneto posted by BTD on September 10, 2001 at 17:16:40:
You probably need to change the flange out for one that will hold the magneto upright, or you will not be able to get the timing in range. I don't think you can just turn the current one. You will need to remove the impulse coupling, which requires a puller and LOT of care to not break the coupling. Replacement couplings are expensive.
Post A Followup
: Re: Re: New magneto
