Re: All kinds of confusion on the M!
Posted by Bob M on September 12, 2001 at 19:00:53 from (66.66.72.246):
In Reply to: All kinds of confusion on the M! posted by Jeff on September 12, 2001 at 15:12:27:
third party image
Jeff - This diagram should do it with 1 minor change: Skip the wiring running from the fuse holder to the ign switch, coil, etc. It's not needed with a magneto.
If you elect to make your tractor negative ground (recommended so you won't get a surprise if you ever try to jump it from 12 volt car), swap the connections at both the battery and the ammeter, then repolarize the generator.
Post A Followup
: Re: Re: All kinds of confusion on the M!
