Re: Help removing Farmall A fron tires
Posted by ---===] jer [===--- on September 15, 2001 at 14:25:09 from (209.180.11.115):
In Reply to: Help removing Farmall A fron tires posted by Jim on September 15, 2001 at 06:27:39:
I just replaced a front inner tube on a model C with a wide front end. It makes me wonder why the wheel has to come off the tractor to change the tire. I just let the rest of the air out and changed the tire on the tractor. You do have to lift the front off the ground, but it works. I guess as long as you loosened the bolt, burning off the bolt will do the job. Next time, leave the wheel on. Hope this helps.
Post A Followup
: Re: Re: Help removing Farmall A fron tires
