Re: how can i tell if its charging?
Posted by Red Dave on September 16, 2001 at 17:31:50 from (63.26.0.59):
In Reply to: how can i tell if its charging? posted by Jeff on September 16, 2001 at 15:45:58:
Jeff, use an accurate voltmeter and measure voltage across the battery with the motor off, it should be about 12.6 volts. Start the motor and run it at about 1/2 throttle, then check battery voltage again, it should be about 13.2 to 14.5 volts if it is charging. If voltage does not increase with the motor running at 1/2 throttle, it's not charging.
Post A Followup
: Re: Re: how can i tell if its charging?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
